It is currently Sun Jul 20, 2025 3:14 am
PostPosted: Tue Sep 17, 2024 12:42 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Needing to have more visibility/ maneuverability than my osc drum sander provides, I'm looking at getting a pin sander. I read some posts here where some of you have Elevate's sander. Looking for any insight on V1 vs V2 style. I don't relish wrapping paper onto a drum (the V2) but thought I would ask- they are kind of expensive.... The only use I have planned is sanding the contour lines of the neck to headstock transition.
Measure Twice,
Karl Borum
PostPosted: Tue Sep 17, 2024 12:48 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Take a look at this—different approach but same goal. https://www.leevalley.com/en-us/shop/to ... ow-sanders
These users thanked the author bobgramann for the post: Kbore (Wed Sep 18, 2024 9:58 pm)
PostPosted: Tue Sep 17, 2024 1:40 pm
Is your Osc a spindle sander or a thickness sander?
PostPosted: Tue Sep 17, 2024 2:26 pm
First name: Brad
Last Name: Combs
I would be scared to sand the neck to headstock transition with it. That’s because I’m scared of it in general. Don’t get me wrong, I use it to flatten sides on every instrument. Doesn’t mean I’m not scared of it. :D
This helps with control - https://a.co/d/9RWDD8j
These users thanked the author bcombs510 for the post (total 2): Pmaj7 (Thu Sep 19, 2024 7:40 pm) • Kbore (Wed Sep 18, 2024 10:00 pm)
PostPosted: Tue Sep 17, 2024 3:40 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I use a Grizzly pneumatic one, https://www.grizzly.com/products/shop-f ... nder/d4595. Works OK for me but I've sanded a side a little too thin before and the sanding sleeves aren't cheap. Check out this one on Amazon, https://www.amazon.com/Spindle-Hand-Hel ... B0CNTDFQHG. It's a way cheaper way to try it than Elevate or Grizz. It's got solid drums too not pneumatic. For that price I think I'll give it a try.
PostPosted: Tue Sep 17, 2024 4:01 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
For that area of the neck (neck to headstock transition), I like to use dragon rasps, rat rail rasps, and then the bow sander referenced by Bob above. It's crazy how smooth it winds up looking after the bow sander has its way with the wood. I worry about using power tools in that area, but I have done it. Things go awfully fast with power tools . . .
These users thanked the author doncaparker for the post (total 2): Pmaj7 (Thu Sep 19, 2024 7:42 pm) • Kbore (Wed Sep 18, 2024 10:00 pm)
PostPosted: Tue Sep 17, 2024 4:52 pm
At times I use sanding sleeves by hand. You can see what you're doing and can vary the shape by squeezing the sleeve. Sometimes power tools get you into trouble real fast.
These users thanked the author bftobin for the post (total 3): Pmaj7 (Thu Sep 19, 2024 7:42 pm) • Kbore (Wed Sep 18, 2024 10:00 pm) • bcombs510 (Tue Sep 17, 2024 5:39 pm)
PostPosted: Wed Sep 18, 2024 2:42 pm
The two sizes of the Grizzly pneumatic sander are a major part of my neck heel - shaft transition.
I use them to hog off wood to get close and finish with the usual rasps, scrapers etc.
ImageIMG_7094 by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post: Kbore (Wed Sep 18, 2024 10:01 pm)
PostPosted: Wed Sep 18, 2024 9:59 pm
First name: Karl
Last Name: Borum
Spindle..... but I cant see the line I'm sanding to with the OSSander
Measure Twice,
Karl Borum
PostPosted: Wed Sep 18, 2024 10:11 pm
First name: Karl
Last Name: Borum
Thats a great picture Terrance.
I took out the center portion of the neck before the heel and headstock. I think I like your sequence better- this was my first scratch neck build. I ended up using dragon files and amazed how near perfect it turned out, although I was having my doubts for a while.
I still want a Pin Sander though....
Measure Twice,
Karl Borum
PostPosted: Mon Sep 23, 2024 1:00 pm
First name: Carl
City: Forest Ranch
I received the pin sander I referenced above. It's got two roller sizes 1" and 1.5" and came with 5 sleeves for each. They seem to be about 100 grit. The rollers are 4.25" long so are great for neck shaping not so much for sides on larger acoustics. I think it was a good deal. Here's a pic along side a Grizzly...
These users thanked the author CarlD for the post: Kbore (Mon Sep 23, 2024 6:07 pm)
PostPosted: Mon Sep 23, 2024 6:14 pm
First name: Karl
Last Name: Borum
Thank you for the update.
I went and looked at those, and a number of similar ones on amazon. The main complaint with most was that they were not eccentric and wobbled badly. Guessing that you didn't have that problem?
I don't have a problem spending the money for the Elevate sander, but was hoping someone would comment about version 1 (use sleeves) vs version 2 (wrap you own paper).
Wouldn't be a bad idea to start inexpensive to see how I like using a pin sander in my shop.
Measure Twice,
Karl Borum
PostPosted: Mon Sep 23, 2024 8:55 pm
First name: Carl
City: Forest Ranch
Slight wobble but about the same as the Grizzly. From my tests it didn't cause a problem. Good price just to see if it works for you.
These users thanked the author CarlD for the post: Kbore (Tue Sep 24, 2024 10:59 am)
PostPosted: Tue Sep 24, 2024 6:46 am
I have V2, wrap the abrasive, no problem with PSA if you follow his method (r. I bought 2 rolls of the 120 grit.
These users thanked the author Colin North for the post: Kbore (Tue Sep 24, 2024 10:59 am)
PostPosted: Mon Oct 14, 2024 7:52 pm
First name: Jon
Last Name: Snider
City: Colorado Springs
State: Colorado
I have the V2 version also. First go around, with the standard paper it was a b*tch to get it off to change. Had to,soak in solvent and then scrape. A lot. I have the newer premium film back paper now which I haven’t tried but it’s not cheap.
These users thanked the author Duct Tape for the post: Kbore (Tue Oct 15, 2024 11:52 am)
